Hi.
I have just started trying to capture DV video from my camera to PC, and have found that any significant motion (eg. subjects running, jumping, or even camera movements) results in some "jerkiness" when the file is played back on the PC. When played back directly through the camera or TV it is fine.
My PC is 450MHz and video card (I think) is 8MB.
Could this be caused because my PC / Video Card is not powerful enough?
Thanks for your assistance.
A common cause of this is a slow hard drive or slow processor. Depending upon your resolution (of the Video) your 450Mhz may be a little slow. Just as much as a factor is the speed of your Hard Drive. For video capture and playback, a minimum 7200rpm hard drive is recommended for full D1 video (720x480).
At high motion parts of your video, the bitrate (or imformation rate) is probably exceeding what your processor can handle, and exceeding what your hard drive can spit out.CrazyPants Productions
http://www.crazypants.com
Are transcoding AV-sync errors caused by hardware or software?
By MarcMiller in forum Video ConversionReplies: 14Last Post: 6th Dec 2011, 16:44 -
jerky motion when deinterlacing - out of sync when not?!
By robotjox in forum DVD RippingReplies: 0Last Post: 11th Jul 2009, 04:51 -
----jerky motion----when did that happen?----
By ozne64 in forum Video ConversionReplies: 6Last Post: 15th Jan 2008, 06:00 -
Jerky motion
By davidk21770 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 24th Oct 2007, 18:41 -
jerky playback at 1440x900 - hardware? software?
By ecc in forum Software PlayingReplies: 4Last Post: 27th Aug 2007, 09:11
