i get up an error when i follow the guide on this page.
i´m trying to extract the audio from a .avi file.
the message is
"The requested audio compression is not compatible with the input format.
check that the sampling rate and the channel count of the input match those of requested format."
i´ve done this before but this´s the first time that this happens to me
PLEASE HELP ME.
If you have Gold Wave, why not just load the .avi file into it? Then save it as the .wav file you need?
Hello. -
The AVI probably has AC3 audio, so select Audio/Direct Stream Copy and then File/Save as WAV. Rename the extension to AC3 and use Headac3e to convert it to 44.1khz WAV or MP2
Try Nandub
available at http://www.doom9.org/software2.htm
It was originally a hacked virtualdub for advanced divx3.11a encoding but the best thing about it is (IMHO) that it handles 'non-std' audio i.e. ac3, vbr mp3, mp3 with no wav header etc....
Use it just like VirtualDub for avi files with non standard audio. -
you have to install the virtualdub with support for AC3 avi.file
from divx digest -
Nope, the regular version of virtualdub will extract the AC3 just fine, it just sticks a WAV extension on the end, which you would have to change to AC3...
Why is Virtualdub doing this?
By skybooks in forum Video ConversionReplies: 4Last Post: 29th Jan 2011, 22:11 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 14:26 -
Virtualdub help
By Rogert in forum Newbie / General discussionsReplies: 10Last Post: 2nd Sep 2009, 16:00 -
virtualdub vs others
By dude112 in forum Video ConversionReplies: 13Last Post: 13th Nov 2008, 23:49 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08
