    Dec 2001
    Cyprus
    Hi
    When I try to cut an MPEG file on the Merge and Cut window, when I try to Run the file I get the following:
    "At address 355....., Read error occured against address 355..."
    Any ideas?
    Regards
    Stelios
    Apr 2002
    Norway
    Might be that the file is bad.
    Try loading it in Virtual Dub and correct errors in stream.
  3. I often get that error, although the file still cuts ok. I think it may be a bug in TMPGEnc.
    Craig
    Dec 2001
    Cyprus
    Hi Knut_Norw
    "Try loading it in Virtual Dub and correct errors in stream."
    What do you mean and how do you do this? Can you please explain in simple terms.
    Regards
    Stelios
