I recently downloaded several avi files that do not have sound. When I right click the file, there is no audio format for the file. Is there a new audio format??? I have d/l & installed the most recent codecs from divx.com. This has happened on 2 screener d/l's since 7/20/02. any help or suggestions are appreciated.
You might try installing the nimo codec pack ("tools" link over on the left).
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Thanks -- I d/l nimo and ogg after reading other posts subsequent to posting my original post -- no luck. Should these work automatically or do I need to somehow "tweak" the avi file for the sound to work???
When you open the file in VirtualDub and select file information, what does it say under audio stream?
The file information using the most recent build of VirtualDub:
Sampling rate: 48000Hz
Channels: 2 (Stereo)
Sample precision: 0-bit
Compression: Unknown (tag 2000)
Preload skew: 12000 (0.25s)
# of frames: 164654
Min/avg/max/total frame size: 12/1001/12000 (160965k) -
The unknown(2000) indicates its AC3. Refer to this how to faq for more info.
http://forum.vcdhelp.com/userguides/91588.php
I use power dvd to play these files. You're probably just missing the ac3 codec on your system, which is why they wont play.
Remove text from file properties
By Pegsitron in forum Newbie / General discussionsReplies: 1Last Post: 2nd Aug 2010, 07:29 -
Change File Properties/Information for Video Files
By MrRedPants in forum EditingReplies: 5Last Post: 16th Jun 2010, 23:33 -
AVI video properties missing
By Ayeohn in forum DVD RippingReplies: 3Last Post: 19th Dec 2009, 03:58 -
Trying to Convert avi. (Dvix) with AC3 audio file to DVD Format
By carlos305 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2007, 08:54 -
Lost Summary Tab on .avi properties
By blueprint in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2007, 16:25
