hey..um..i just used TMPGEnc to make a vcd and it worked but now when i try to do it, it won't. i don't know what to do it won't read the d2v file i make. i went to the troubleshooting section and this is what they said
"In Order for TMPGEnc to recognise D2V files, you MUST have the VFAPI and the DVD2AVI.VFP file located where the TMPGEnc.EXE file is! it will NOT work any other way! It is also sometimes helps to use the Forced Film option in DVD2AVI, but only if you are still unable to open the D2V files with TMPGEnc. (suggsted by msfox)"
and i know this is what im doing wrong but i dont' know what they mean can someone please help me. i'd really appreciate it.
p.s. im not a computer expert so..go easy on me please
aight
thanks for just reading my post
First off when you downloaded tmpgenc you also needed to get the VFAPI file for the same version as your copy of tmpgenc.
Check tmpg options menu, environmental settings and vfapi plugin and make sure the boxes are ticked.
If not there, search for tmpg and the site will probably have both files. In case you forgot, get it again and install it. See if that helps.
0, -1, -2 is priority of the filter (one of them is the file reader you need)
Why don't my DVD copied onto hard drive play any more?
By kib in forum DVD RippingReplies: 1Last Post: 16th Nov 2010, 06:39 -
DAT to DAT cutter?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2010, 12:13 -
Tmpgenc Xpress 4: I Don't Want To Resize
By Tom Saurus in forum Video ConversionReplies: 17Last Post: 16th Nov 2009, 15:18 -
Subs don't show properly I don't know what to do
By atai in forum SubtitleReplies: 1Last Post: 8th Oct 2009, 08:44 -
I have a .DAT file and don't know what program I need to open it
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2008, 16:42
