I've been picking up some movies configured with very low
fps (12.500). I've converted one using the Low-Bitrate
tutorial (http://forum.vcdhelp.com/userguides/91597.php).
And to say the least, it didn't come out very well.
My question, is there a better way to convert these movies
to either VCD or SVCD to play on my standalone player? The
complete specs on the avi file is as follows using VirtualDUB's
File Information:
Video System
Frame Size, fps.....................................352x288, 12.500 fps
# of frames (time).................................47488 (1:03.19)
Decompressor...................................... .DivX MPEG-4 Low-Motion
Number of key frames...........................380
Min/avg/max/total key frame size..........2582/7915/17266 (2938K)
Min/avg/max/total delta frame size........248/3017/22442/ (138799K)
Audio System
Sampling rate.........................................24000 Hz
Channels.......................................... ......2 (Stereo)
Sample precision.....................................0-bit
Compression....................................... ....Fraunhofer IIS MPEG Layer-3
Preload skew..........................................3172 samples (0.13s)
Min/avg/max/total frame size...................435/560/3172 (25970K)
Any help will be greatly appreciated.
Why doesn't this work?
there's just no way you're going to get a good result encoding from a source with that low a framerate.
sorry...it's just not going to happen
what are you askin' me for...
I'm an idiot! -
Yes.. but you aint gonna like it.is there a better way to convert these movies
1) use tv out of your video card and copy to VHS (or SVHS)
2) Capture back from VHS using analog capture card
3) re-encode AVI file to MPEG
[/quote] -
you could try using a screen capture program (like camtasia) to record the video to avi as you play it using wmp
As we all know, your problem is not enough frames for smooth playback. Most apps, even if you convert to a higher framerate will just duplicate existing frames to pad and which will still leave a jerky motion.
I read very recently of an encoder/converter that claims to predict the intended motion of the action by comparing the change between 2 or more successive frames. So if there was no change it would duplicate those pixels. If there was a change it would plot a point (% way) meaning 1/2 way or 1/3 way depending on how many frames were being added.
Heres where someone can help!
Where in the world did I come accross this info and where on my HD's or backup cd's would I have put that info. Give me a clue if you know what I am talking about and I will find it. -
I was afraid that was going to be your answers.
Trying some hope and prayer filters doesn't do
much either. I guess its that old axiom, "Trash
in, trash out."
Thanks again for all you help!Why doesn't this work?
HandBrake Low FPS
By Guess Who in forum Blu-ray RippingReplies: 6Last Post: 17th Oct 2011, 11:27 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
Low fps
By dylanvega123 in forum Video ConversionReplies: 8Last Post: 15th Jul 2010, 03:47 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
Vista64 playing wow with low fps
By johns0 in forum ComputerReplies: 13Last Post: 28th May 2007, 19:57
