Hi, I converted a 24min DivX-->VCD using the perfect guide on this website. I followed every step, made sure my fps and everything was correct. I did not convert the avi using the wrong setting it was a NTSCFilm file to NTSCFilm!
The problem is when i go to play the VCD on my DVD player it will start playing the audi and the movie only the movie will stop moving for 1-2secs, skip some frames, and start moving again! This happens about every5-6secs.
My DVD player is a JVC XV-421. I've tried using VCDEasy and Nero to burn my VCD but i have the same problem every time! PLZ Help!
Hola Hola!!!!!!!!!
Hola Hola!!!!!!!!!
Stay Fit, Eat Right, Die Anyway! -
Just some thoughts for now:
The mpeg plays fine on your pc before you burn it?
Your DVD player accepts vcd at 24 fps (mine skips unless its 29.97)
Did nero compalin about compliance and did you try to let it fix it for you. -
YupThe mpeg plays fine on your pc before you burn it?
It Skipped on bothYour DVD player accepts vcd at 24 fps (mine skips unless its 29.97)
Nero didn't complainDid nero compalin about compliance and did you try to let it fix it for you
-I'm beggining to think it's my dvd player, but if you have any more advice for things i could do on the software side of things i'd be more than happy to hear it!Hola Hola!!!!!!!!!
Hola Hola!!!!!!!!!
I figured out my problem!
Turns out that my DVD player didn't like the brand of CD-Rs I was using!!
I tried burning a different brand of CDR the same way i did with the ones that didn't work, and it worked
WOOOOOOOOOOHOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!Hola Hola!!!!!!!!!
Hola Hola!!!!!!!!!
picture but no sound when playing minidv cassettes
By gensol in forum Newbie / General discussionsReplies: 4Last Post: 24th Mar 2011, 11:04 -
FLV skips few frames back and forth while playing
By Mylo in forum Video Streaming DownloadingReplies: 3Last Post: 2nd Apr 2009, 21:56 -
blu-ray picture skips in extras
By tooears in forum DVD & Blu-ray WritersReplies: 3Last Post: 29th Oct 2008, 06:39 -
no picture when playing videos
By templar67 in forum Newbie / General discussionsReplies: 5Last Post: 7th May 2008, 17:24 -
Prevent automatic scaling/zoom of picture when playing a DVD
By pk20 in forum Authoring (DVD)Replies: 5Last Post: 7th Sep 2007, 03:30
