  1. Ok if i have a SVCD burned onto a CD-R can i get it to a VCD? Please be specific i am not very experienced with this stuff!
    Jul 2002
    Oregon USA
    Well yes, it can be done. I don't know if this is the correct way but this what I do.
    I lay out the MPEG2 file into an avi using either Ulead Video Studio or FlaskMPEG, then use TMGEnc.exe to convert it to mpeg1 that allows me to then use VCDEASY to build a bin/cue and burn it for viewing
    you don't need to convert to avi
    www.vcdhelp.com/mpeg2tovcd.htm
