Results 1 to 10 of 10
  1. HI,
    I have an ATI AIW 32mg, Soundblaster AudioPCI 128 soundcard. When I try to send a clip to my VCR (JVC) using S-Video in, I get a perfect picture but no sound at all. When I try to caoture from the VCR, I get nothing at all!
    All the links appear to be correct: Output has the S-Video from the output socket, the audio cable from the speaker socket/ Input has the S-Video into the input socket, audio cable to the Line In socket. yet no sound outwards and nothing inwards.
    ANy suggestions?
    Bill
  2. check the installation and setup users guide
    that came with your ati aiw 128
    if it's the same guide as I've got
    pages 23 to 30
    it'll explain how to install and get both in and out working properly
    and if you still don't get any audio in on your computer when you want to record something
    load the television application on your computer
    then click on the checkmark button(bottom right of the controls)
    click on the Display tab
    go thru the wizard and when you get to Sound Initialization window
    set the Audio Input for line in
    and everything should be working fine
  3. Hi,
    I bought the card through Ebay, so no installation guide! Can you email me privately with the info?
    billlowery@tinyonline.co.uk
    Cheers
    Bill
  4. The information is available on the ATI site:
    www.ati.com
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  5. hi
    if you haven't found the exact page for the user's guide
    here ya go
    just make sure you've got the acrobat reader from adobe
    if not there is a link on that page to get it
    http://www.ati.com/support/products/pc/rage128/aiw128manuals.html
    first manual
    which is
    Installation and Setup User's Guide Version 4.0 Revision D
  6. Originally Posted by LabanB
    HI,
    ANy suggestions?
    Bill
    You know the svideo cable to your VCR only carries the video signal and not the audio as well. You should also have a pair of phono/rca cables going to the VCR from the output of the card.
    Craig
  7. Hi Guys,
    Thanks for the info. Yep, I have the pair of rca cables. I will let you know what happens
    Bill
  8. Hi Guys,
    Well the video out to VHS works atreat. Cheers.
    Now the next problem! When I try to capture using the ATI AIW, whether using the ATI Video In TV gizmo, or MGI VideoWave 5 (my favoured tool), there is no sound (yep, the leads have been swapped to line in) and although the screen appears to be finding something, it is not finding the video I am trying to capture. Any ideas?
    Bill
  9. for the ATI AIW
    *repost*
    go thru the wizard and when you get to Sound Initialization Wizard
    and the channel is something questionable
    cuz any other program will try to use the channel specified there
    don't know about mgi videowave5
