I try to convert some AVI movies (200mb)in TPMGenc to make a VCD but he said,
file can not open or not supported. can someone tell me what do i wrong!!
I try another small movie and it works.
you are missing some codecs. d/l and install the nemo pack in the tool section then try your file again
Also check the "how to - newbie" section link, then "tmpgenc common problems" (that one is in there with a solution).
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
how to convert dvdrip avi's to vcd
By kissme1 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 9th Dec 2008, 15:19 -
TPMGEnc DVD Author 3 Menu Problem
By ^D3vIL^ in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2007, 17:43 -
AVI comes upsidedown using TPMGenc 4.0 XPress for editing
By rominho in forum Newbie / General discussionsReplies: 4Last Post: 17th Jun 2007, 19:38 -
By rominho in forum EditingReplies: 0Last Post: 14th Jun 2007, 09:09 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
