Wish to capture AVI files.
VirtualDub captures MS YUV 16 bit. When imported into my editor (Ulead VideoStudio6) it will not edit (etc).- reports as unsupported format. VS6 uses "DV Video encoder type 1" (whatever this is) and 24 bits. The imported clip can be rerendered by VS6 (very very slow) into their 24 bit format.
On the other hand VS6 does not want to capture high res AVI, their tech serv sais it is the capturing board's fault. (Xtasy Everything 5564 - NVIDIA GeForce2 MX/Mx400). Where do I go from here, who is passing the bucK?
Under Virtualdub's custom format do any other options open up?
If you are going to process to Mpeg1 after it is recommended that you try the yuy2 format if it's available.
To use the custom format don't use compatibility mode for compression or to capture or it won't work.
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 16:14 -
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 02:17 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 10:40 -
Vista Home Premium x64 (64-Bit) vs x86 (32-Bit)
By Shibblet in forum Media Center PC / MediaCentersReplies: 8Last Post: 30th Sep 2008, 18:42 -
Making 32-bit VFW-ACM codecs available to XP 64-bit Edition.
By gastorgrab in forum EditingReplies: 5Last Post: 19th Aug 2007, 12:12
