hi i need help taking my Video from my DV Camera and burning it to a DVD+RW what is the best way to do this and what format is the best to do it in. like svcd or mpeg2 and what program should i use to capture and burn it. i got the HP dvd100i the software that came with that looks pretty good.
THANKS![]()
1. Get a firewire card (if you don't have it yet). Better if you can get a card with a software. StudioDV is good for starters.
2. Get TMPGENC (in TOOLS). You'll need to create MPEG2 out of your DV-AVI files.
3. From this point on, it really depends on what your target output is. So you might want to check the 'HOW TO' on the left (Capture, Convert, etc). -
Yeah. This is my problem too. I made many SVCD, VCD many times from my DV Camera with no problem.
But this time I wanna try to make those DV avi files to DVD. I have no problem to convert it to mpeg2 using TMPGENC. But those files are mpg files, NERO 5.582 does not like it, it say that those files are not DVD compliance.
Since I noticed that DVD files are VOB. How do I create VOB files from my mpg2 files that I created using TMPGENC?
I followed the instruction here in this forum using TMPGENC to de-multiplex those mpeg2 files. But it creates .mp2 & .m2v files instead of .vob files.
Please HELP !!
Have you seen a video camera connects a DVD burner directly without PC?
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 8th Oct 2010, 06:39 -
JPEG Digital Camera & MP4 & FLV
By Russo in forum Newbie / General discussionsReplies: 3Last Post: 8th Jun 2009, 16:03 -
Jumper settings for Hardrive & DVD burner
By CapeKO in forum ComputerReplies: 3Last Post: 15th Mar 2008, 21:41 -
Blu-ray / HD DVD player & DVD±R/RW burner - $409 (eSATA) or $429 USB
By joepic in forum Latest Video NewsReplies: 12Last Post: 13th Feb 2008, 19:30 -
Hey can tell me the best performing, most reliable CD/DVD Burner & Medi
By uncleB in forum DVD & Blu-ray WritersReplies: 26Last Post: 8th Feb 2008, 15:22
