Hey I just recently used dvdtosvcd and I might add it did a wonderful job.
Here is my problem, it converted them into 2 cue files, the first cue file burned perfect the size was 825,562kb and it plays great and looks just like a dvd.
Now the 2 cue file: When I go to burn it using Nero it spits it back saying not enough free space on cd *its size is 854,456* the cd capacity is 700mb 80min. Is there anyway to get this to fit to that cd? Can I crop or cut maybe the cast at the end out?
You can cut the last part, using TMPGEnc, or BBmpeg.....or you can buy a 90min, 99 min CDR (for video: 900 and 990MB) and burn it on such a disk....if you burner supports this format.
The Dutchman -
Cameron2003
My question is why did you get such sizes? Are you using TMPG and choosing CQ ? I have DVD2SVCD'd 40 rips so far , and using the bit rate setting tab, have never encountered your problem. Also have not had a file bigger tha about 810 mB. -
You said the file is 825MB, is that according to Nero or Windows? All my bins from DVD2SVCD are ALWAYS around 825. If Window reports 825, try burning it with something like CDRWIN. If Windows reports 854 you will not fit it on an 80 min CD without cutting/re-encoding. To cut or re-encode however you will have to extract the .mpg from the bin and re-image to bin/cue.
.iso, .img, .cue, etc. to DVD
By Xandal in forum ComputerReplies: 5Last Post: 26th Aug 2008, 12:52 -
cue sheet problem
By Snowcrystal in forum AudioReplies: 2Last Post: 2nd Sep 2007, 13:29 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
