  1. I'm running VPC (4.0.2) and everytime I try to run Fireburner 2.0.8 I get the following error "A required .DLL file, QTINTF.DDL, was not found". As a result, I cannot run fireburner (and not create SVCDs since this Fireburner is required). I was wondering if anyone knows how I can get fireburner to work or shold I just create a new VPC hard drive.
  2. I had something similar happen to me a while back, and I discovered that what I had done was move the FireBurner application out of the folder it originally came in -- it turns out that there are a couple of "invisible" files (that Windows doesn't show you) that live in the same directory as the FireBurner app, and so when I moved it, FireBurner stopped working (with a similar-sounding error).
    I'd say just reinstall FireBurner where you want it to be and then don't move it around, and see if that helps. ?
  3. I had the same trouble. Go nback to the fire burner and download the Other, older version. I believe that it's v1.06
    open the program and drop the .cue and .bin files on the Fireburner open window. .cue first, let the prog process the file. When the window says that the task is completed, drop the .bin file on the window. The .bin file takes much longer to process than the.cue
    Then, drop both the processed results on Toast 5 with Multi track CD-ROM XA selected.
    Good luck. It worked for me.
    Dave
