I own a Hauppauge WinTV PVR USB, and like it quite well. I have been doing SVCD captures from Laserdisc with it with great results. I have made 1 VHS tape capture that was 55 minutes long, and that looked pretty bad, even at 2200 kbps, however the sounds was in sync.
I have twice tried to capture a colorized commercial movie that is 97 minutes long and on both captures, although the audio/video is in perfect sync played in PowerDVD, cutting the files throws it out of sync. This is the first time I have had any sync issues when cutting with the Hauppauge. I am wondering if somehow the colorization is causing the problems, or it's due to the tape length or what exactly. Macrovison is not the problem, as my VCR is a GoVideo unit.
Any ideas?
It must have been due to the tape source, as I captured a 97 minute movie last night from Dishnetwork and it was in perfect sync, even after cutting.
AverTV USB HD DVR or Hauppauge USB HD PVR
By gll99 in forum Capturing and VCRReplies: 34Last Post: 8th Jun 2015, 10:56 -
Capture with Hauppauge WinTV PVR.500 VHS
By Asesinato in forum Capturing and VCRReplies: 2Last Post: 31st Mar 2012, 11:33 -
Which is better quality capture- DVD recorder or Hauppauge WinTV USB stick?
By akalsha in forum Capturing and VCRReplies: 9Last Post: 6th Mar 2012, 19:57 -
Hauppauge WinTV-PVR 250
By thatsgame1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jun 2011, 07:54 -
Hauppauge WinTV 2Go capture card was Kworld DVD Maker USB 2.0
By Vampire74 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2008, 10:59
