Hi All,
I recently received a DVD-R from the States (I'm in region 2). I tried to play this DVD-R in my player and it just spun in the drive - nothing.
I then tried converting to Region 1 using the hacks on this page and still got nothing. I know I got the hack right cos I tried a region 2 DVD in after and the machine told me that the DVD was from a differnent region.
I've reset to region 2 now .
Is my problem caused by the fact that DVD 711 Philips won't play DVD-R's ? Or is there some clever way I can get it play this one ?
Regards
Andy
I have the same question, how to do a Philips 711 play DVD-R?
I tried with 2 DVDs made by a friend, one worked perfectly, the other , no chance.
Please, what is the secret? -
I've noticed that when using DVD-R on philips the disc must be full. It's not able to read the unburnt bit at the end so doesn't know what disc it is.
I suggest using discs with around 4gig of data on it. You can create a padded file to fill the disc up before burning. -
Hello,
I have the Philips DVD711 and have gotten DVD-Rs to work fine. A few notes: The disc must have 3.8GB or more. Don't use Nero. GearPro DVD6 makes everything great!
Goos luck!---
MovieMan
Athlon 2000+ w/ATI AIW Radeon
SVCDs Rock!
DVD Disk Lock??? i locked my dvd player i need password! (PHILIPS DVP3520)
By kamzo91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Aug 2010, 15:14 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Toshiba DVD Drive does not recognize Philips DVD-R media
By garybeck in forum DVD & Blu-ray WritersReplies: 12Last Post: 5th Nov 2007, 13:57 -
Moser Baer DVD+RW Burnt As Data DVD Freezes In Philips DVP 642K
By yohu123 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 4th Sep 2007, 13:51 -
Repairing the DVD Drive -- Philips PET 1000 Portable DVD Player
By ORSteve in forum Portable VideoReplies: 1Last Post: 13th Aug 2007, 13:45
