HI GUYS,HERES THE SCENARIO.TRYING TO GET WAV FILE ONLY FROM DIVX MOVIE TO MAKE A DVD.MOVIE FILE INFO:VIDEO:MPEG 4 LOW MOTION...:AUDIO:48000HZ,CHANNELS:5(STEREO),COMPRES SION:UNKNOWN(TAG 2000)...
WHEN TRYING TO CONVERT,SETTINGS, FULL PROCESSING MODE, AUDIO CONVERSION,44100HZ AND TRIED 48000,HZ.COMPRESSION ,NO COMPRESSION(PCM).
ALL IWANT IS THE WAV FILE!!!THEN WILL USE IN TMPGE TO CREATE DVD.
CAN YOU PLEASE HELP???? THANKS IN ADVANCE!!
[/b]
Can it load it Gold Wave? If it can and when you do it, just save the file as a .wav file. I know Gold Wave loads .avi and .mpg files. And please turn off your caps lock. It is very annoying (like shouting).
Hello. -
the audio might be an AC3 stream. check the guides on the site on how to convert/extract the audio
ok,thanks,got wav file from gold wave!now in tmpge another problem!load wav ,load video,dvd template,cbr,3000 kbs,layer 2 48000kb,mpeg standard.when played back film is very jerky and sound fades in and out!!film almost like slow motion!never had this problem before!when playing back just wav file it is great!when playing video divx version is great!after tmpge some things happening!tried both different fields,top and bottom,tried both interlace and non interlace,tried a higher bit rate,still the same.thanks in advance!oh 23.97 fps(internally 29.)cant chage this.not sure if this could be problem!thanks in advance!
How do I get the exact file size I want with Virtual Dub ?
By Simmons in forum Video ConversionReplies: 3Last Post: 21st Jul 2011, 01:32 -
Virtual Dub delogo output file help
By Rogert in forum Newbie / General discussionsReplies: 3Last Post: 7th Jun 2011, 12:25 -
I have suddenly lost the ability to convert to DiVX with Virtual dub
By DaneClark in forum Video ConversionReplies: 6Last Post: 8th Jul 2009, 07:16 -
Audio out of sync after running file thru virtual dub
By AORMan in forum Video ConversionReplies: 3Last Post: 2nd Oct 2007, 13:35 -
how to batch file in virtual dub?
By warlock110 in forum Video ConversionReplies: 2Last Post: 17th May 2007, 00:56
