Ok, i started with a divx avi, the used tmpgenc and made it into mpeg1. It took about 4 hours. I then burned it to a 700 mb generic grey/blue bottomn cd-rw (my dvd player can only read cd-rw) I stick the disk into my dvd player and nothing shows up, the numbers on the dvd player were moving as if it were playing, but i saw nothing (just the sony dvd logo) After that, i tried to play the .dat file on my computer and it plays a black screen for the whole 57 minutes. I used nero 5.5 to burn, can someone suggest what is wrong, or tell me how to check if my mpg is compatible??? thankyou im VERY frustrated
-adam
i presume you used the video cd pal mpeg-1 template before you started. when it finished coverting did you see if it was a movie clip mpeg-1 let me know how you got on.
your's e.c.t.
sparrow
Hey, thx for the reply sparrow... now i KNOW i did something wrong because i have no idea what you are talking about... i opened my avi in tmpgenc and then followed the instructions on the how to convert page for tmpgenc. Can you please explain thx
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 22:13 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 15:35 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 12:25 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54
