  1. hi, im stuck on that one
    i ripped some dvds meanwhile, but that one got me
    ripped with smartripper on hd
    vobs play fine WITH sound in windvd
    i made my *.d2v projekt using dvd2avi
    video encoding all fine
    now, audio *.wav
    dvd2avi makes me an *wav file wich is too short, well, not really
    in media player it shows me about half the time (44min instead of 1.30h)
    when i listen into the wave file its like double speed
    so i think dvd2avi got all the audio but make it cpl. too fast, so my
    audio track is then "too short"
    so i tryed some diff settings in dvd2avi but always comes out the same
    then i tryed vob2audio there nothing happens at all
    (cant hit the audio stream button)
    may any ideas ?
    thx ahead
  2. update
    also tryed now with smartripper to demux the audio directly
    same result
    may that helps
    Stream[001] 0=[[0xE0] Video PAL 720x576] [PTS 0:06:00] [Delay 0 ms] [@0] []
    Stream[002] X=[[0xA0] Audio Deutsch LPCM(1Ch) 48kHz 16bit ] [PTS 0:04:40] [Delay -80 ms] [@0] []
    thx ahead
  3. Guest
    I am experiencing the same problem, so view this thread:
    http://forum.vcdhelp.com/viewtopic.php?t=106194
