I just upgraded my win98se to win xp, n also changed from fat32 to ntfs.
BIG PROBLEM !!!!
Everytime I start capturing, it looses frames like hell!!!!
pentium 1.5 128mb voodoo 3dfx studio pctv
What to do?????
THANXS
What program are you using to capture? (if its a minor program try using Win98 Compatibility & see if it makes a difference. Find the "program.exe" ,right-click-->properties--> one of the tabs will have a dropped down feature to change to Windows95 or 98 for that program only.)
Have you updated the graphic card drivers to WindowsXP? (Are there WindowsXP drivers at the Voodoo site?)
How much system memory you have installed? (WindowsXP requires more than Win98 preferrably 512K or higher)
Since WindowsXP needs more memory, & if your installed memory is marginal then you probably do not want to run any other apps. in the taskbar while capturing.
Check to see that DMA is enabled for your hardrives after you upgraded.
Are you using 2 separate drives for WindowsOS and for video capture?
Consider al these questions as a way to proceed in finding a solution. -
Just an FYI on drivers, patches and ??? for 3dfx.
http://www.voodoofiles.com/3dfxhelp.asp
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 13:24 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 23:53 -
Archiving lots of DV
By nsdn in forum Video ConversionReplies: 6Last Post: 14th Oct 2007, 13:07 -
Daytek DVR-P30: lots of 'fails' when erasing, lots of nothing when recordin
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Jul 2007, 16:43
