I was wondering
If you convert a Widescreen movie into VCD is the video supposed to look like it is sqeezed in a little?
Mine does it
Any ideas?
When I encoded it using TMPGenc I told it to go it 16:9 but it did not do it that way
Should i leave it 4:3 NTSC?
Thanx
"Computers are stupid, but they are capable of being stupid one million times per second"
Try a 10 second clip and see if it works. If it doesn't, try something else. You don't need to do the whole file to experiment with something like this in TMPGEnc.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 01:06 -
How to create a BluRay from odd format videos and not distort the picture?
By Peterk312 in forum Video ConversionReplies: 5Last Post: 16th Jul 2011, 20:49 -
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 16:41 -
[DV issue] Odd fields bitmapped in grey (and no picture)..?
By Gew in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 17th Aug 2009, 10:56 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00
