I am trying to convert dvd to a d2v file to put on vcd, the problem I am having is after I rip the dvd I try to convert it using dvd2avi when I load the project all the settings are correct like any other dvd but when I start to convert it starts out slow then 30 seconds in to it it speeds up and finishes in less than a minute. I know this is not normal cause I have done alot of other dvds and it usually takes an hour to convert. I have tried everything can you please help?[/b]
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 20th Aug 2010, 00:11 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 10:47 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 09:38
