Could anyone provide me with details how do i rip svcd (mpg) to divx avi
virtualdub gives me error -> "MPEG Import filter: pack synchronization error" when i try to open svcd (mpg) file
how do i fix this?![]()
if you know how to rip a dvd using DVD2AVI and GKNOT(also using NANDUB)
then you can load the svcd into dvd2avi
and go thru the same steps as if you were ripping a dvd
and convert it to sbc divx avi -
Thanks for replying so fast, but now i got yet another problem, i used DVD2AVI to rip my .mpg (svcd) file and, it made 2 files, one for audio and one for video, how do i merge these two files?
since you're converting svcd to divx avi
go thru the steps you normally would do to convert the svcd mpeg to sbc divx avi
as for that .mpa file dvd2avi made
if you've got the program CDEX
if not get it here - http://www.cdex.n3.net/
you can rename the .mpa to .mp3 and convert it to wav
with that program
then load the sbc divx avi file and the wav file into vdub
to merge together and convert the wav to mp3 with the bitrate you chose in gknot
tho in gknot the audio bitrate is mainly for VBR not CBR
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
divx to avi with divx author
By pred in forum Video ConversionReplies: 4Last Post: 12th Nov 2008, 23:32 -
avi to DivX using divX converter pro
By Deaf Raiders in forum Video ConversionReplies: 3Last Post: 19th Dec 2007, 13:28 -
Convert this avi to DivX avi (GSpot Screenshot included)
By indiannawaf in forum Newbie / General discussionsReplies: 13Last Post: 22nd Aug 2007, 11:26 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
