I already had some disappointing results with the WinTV PVR and the Matrox G450eTV, although the problems might be caused by the rather slow system I have, based on P3-500Mhz.
I now consider upgrading to a P4-1,8 or 2.0Ghz but I am still in doubt which capture card to buy, again one of the already tried, or another one e.g. the AIW Radeon 8500 or 7500 (Hercules 3D Prophet).
The things I would like to do are capturing TV and storing it on cd in svcd quality and transferring vhs recordings to cd, also as svcd and all that with good synch results and with good video quality.
My OS is Windows 98SE.
Are the AIW Radeon 8500 or 7500 worth considering and if so which one should I buy ? Do they both work well under Windows 98SE ? (Hercules says Windows ME or 2000 is required). Or are there better options ?
I would appreciate it to hear some opnions.
TIA
Ton
Results 1 to 1 of 1
Capture Card Unigraf UFG-03. Where is I can buy it?
By Andrey97 in forum ComputerReplies: 3Last Post: 3rd Feb 2011, 12:51 -
I'm having a problem deciding what Capture Card to buy
By Mufc in forum Newbie / General discussionsReplies: 3Last Post: 10th Apr 2010, 10:10 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Looking to buy a capture card or any other related product.
By jonathan3566 in forum Newbie / General discussionsReplies: 11Last Post: 7th Jul 2007, 02:10 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
