I made a test svcd to see if my standalone dvd player would play it
and it plays the video nicely
tho i have the problem that the audio sticks then continues every 20-30secs of play
is there a certain bitrate i should use for the audio?
adding this since i didn't mention it
used tmpgenc and the svcd (ntsc film) template
didn't change anything except for the motion search
so it's 224kbits for audio
Your video bitrate is film 24 or 23.97 fps.
My players doesn't like that rate it makes the audio jerk every 10 seconds or so.
At 29.97 its perfect but the filesize increases. Sad to say I tried every trick, its the only thing that fixed it for me. I saw a number of others had the same problem and seem to have done the same.
Funny how what may appear to be a video bitrate issue would affect sound. Truth is one thing I meant to try but never did is to max the audio bitrate to 384 (or something like that) and leave the video at 23.97. It was just a random thought but I never got around to trying it. -
video bitrate is 23.976
I'll give it a go and see if it works
maybe you fixed it for me
thanks a bunch
it worked like a charm
both video and audio are now running properly
Question on USB Memory Sticks..
By SE14man in forum Newbie / General discussionsReplies: 17Last Post: 15th Feb 2012, 10:57 -
Keep incense sticks and smoke away from your discs!
By bizzybody in forum Newbie / General discussionsReplies: 5Last Post: 19th May 2009, 21:12 -
Need cheap USB sticks
By SingSing in forum MediaReplies: 8Last Post: 2nd Nov 2008, 11:21 -
AVI sticks / stutters
By kr236rk in forum Authoring (DVD)Replies: 8Last Post: 20th Oct 2008, 18:41 -
Authored DVD sticks
By lbigfoot in forum Authoring (DVD)Replies: 5Last Post: 11th Jan 2008, 13:41
