Ok so im ripping Big Trouble In LIttle China.
It goes through Smartripper fine. everything seems ok
I throw it into DVD2AVI and make sure everything is checked. VFAPI, Forced Film, Normalization at 100. all the normal stuff.
When it completes the process and i check the folder all i get is a .d2v , no .WAV file.
THis is the first dvd i encountered this with....any ideas as to why it happens...is it the rip or is it DVD2AVI?
-Eat shit and die
Try ripping Track 2 instead of Track 1. Its common practice to leave the first track blank and to mark Track 2 as the default.
you may also check with ifo edit wich track you want
when opening the ifo, you see wich track is what then you
better can choose what you want -
Originally Posted by alturismo
GOTSent deleting files upon completion
By draco_nite in forum Video ConversionReplies: 1Last Post: 2nd Nov 2010, 10:16 -
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 09:47 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38 -
.MP4 to .AVI Conversion Issues - Loss of Sound, Won't Run to Completion
By gumrunner505 in forum ffmpegX general discussionReplies: 1Last Post: 10th Oct 2007, 19:49
