I dont know what i am doing wrong. everytime i use smartripper on a dvd-9 just to rip the movie to an m2v and ac3 file i only get half to 3/4 of the movie. if anyone has an suggestions it would be a GREAT HELP
how are you ripping the DVD in smartripper ?.
if it's extracting the video to one file you will need NTFS as fat or fat32 does not support files over 4 gb. smartripper doesn't complain but you end up with a file of around 3.99gb -
sorry misread your original post, you'll need NTFS to rip large DVD's to a single .M2V file as the video is over 4gb
yep NTFS all the way with u 2 guys i just got a 80gig H/D for 92notes so it was well worth the money to run a dual boot win ME/XP system
just rember u cant c anything formated with NTFS format when using any win95/98/me OS
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39
