  1. I have problem with this program. I'm trying to encode Divx w/ Ac3 to SVCD but nothing is encoding. It looks like it works but it's not encoding anything. The progress bar goes up but the source position stays at 0 at all times. Does anybody have this problem??
    BTW, im encoding Blade 2 DVDrip
    thanks
    Mar 2002
    canada
    if you are useing 2pass vbr then the screen stays black until you get to 50%,then it will start the actual encodeing 8)
  3. thanks for the info
    i'll wait till it hit 50
  4. Free Flying Soul liquid217's Avatar
    Feb 2002
    im betting your using 2 pass vbr in tmpgenc. You won't see the frame count move untill the project hits 50%. The first 50% of the encoding is basically a scan pass. It evaluates the source for when to give it more bitrate or less ect.
    On a side note, if your avi has an ac3 stream, your going to be running into a headac3he.
    http://forum.vcdhelp.com/userguides/91588.php
  5. Free Flying Soul liquid217's Avatar
    Feb 2002
    heh heh, little late
