Boy I've tried a lot of stuff, with no luck. Half of my captures are dropped frames. The best is 37 out 85! I've got 1.7 Celeron with Shuttle mobo...downloaded all latest bio and drivers. 512 ddr memory. 80 gig WD 7200 hard drive, and WinXP Pro. All running through the well-rated VisionTek Xtasy Everything personal cinema. Couldn't get the WinDVR software to work after numerous installs of it and the WDM driver. Used VirtualDub, and it worked, but it was terrible. Glitchy, fast speed, clicky audio- all the problems caused by frame dropping. Checked DMA on drive..you name it. I'm trying to do a VHS to VCD with a factory tape (Beatles Hard Days' Night). Tried other tapes, same problem. Am about to buy a Super-VHS VCR hoping that would help (using composite video input and sound card now). Tried calling tech support at Visiontak, and was on hold for 40 minutes before I bagged it. Also tried emailing...no reply. Their support SUCKS!! I don't know how you other guys got through, but NO WAY for me. I'm considering making a dual boot machine with WinME, and setting up this stuff in ME. Should have bought a DVD burner, I guess...
My email is timetnl@adelphia.net
Have you made sure that you have minimal resources running in the background. If possible run only Systray and Explorer besides your capture software.
Also, you mentioned that you have a 80Gb Harddrive, is it either partitioned or are you capturing to another hard drive?
Your Captures should go go a different drive than your C drive if it's not already.
These two things can be a big culprit to capture success.
Dezine (Michael) -
Make sure the harddrive is defragmented. What resolution are you trying to capture at? You should use 352x480 for VHS. Another app to try is AV_IO.
Drive is brand new, but not partitioned. Already knew about the system tray... I even turned off my cable modem! 352 by 480 made the picture look elongated, as I tried it already. I'll look into that other app. Can I partition my drive now that I've already got XP on it, or do I need to start over. If I start over, it's goodbye to XP..it sucks IMHO. Thanks for reading this!
DVD frame dropping.
By videosam in forum Video ConversionReplies: 20Last Post: 4th Aug 2010, 05:00 -
Dropping one single frame in a two hour capture?
By justin81 in forum Capturing and VCRReplies: 5Last Post: 13th May 2010, 10:38 -
Flickering / Fluttering / Frame dropping...is this copy protection??
By mik534 in forum DVD RippingReplies: 9Last Post: 2nd Oct 2009, 07:55 -
Dropping frame with profile H.264
By n69 in forum Video Streaming DownloadingReplies: 2Last Post: 22nd Dec 2008, 22:41 -
is this pinnacle, dazzle or my new PC causing my frame dropping problems
By arthur1971 in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2007, 03:41
