All,
I'm trying to convert from making VCD to CVD, and to make a "DVD" compliant CVD, I should capture with 48kHz sound. Using ATI's MMC 7.5, it only allows sound capture up to 44kHz.
Is there a newer version with 48kHz capture, or does anyone know a (relatively) painless way to convert just the audio?
THanks!
-Anthony
Yes, that's one of the improvements in MMC 7.7, 48KHz audio capture.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Thanks, Mirror_Image! I guess I'll bite the bullet and download it. The last time I upgraded MMC versions, it was a traumatic experience (blue screens everywhere)... so I was avoiding that if at all possible. Is MMC7.7 stable, or at least as stable as any ATI application?
Thanks,
Anthony
ATI AIW 7500 64M Replacement?
By TaranScorp in forum Capturing and VCRReplies: 20Last Post: 6th Aug 2009, 12:56 -
ATI AIW 7500 TV tuner washes out every 6 seconds, then back to normal
By Keitho in forum DVB / IPTVReplies: 0Last Post: 15th Jan 2009, 14:01 -
Capture problem with ATI Radeon HD 2900 XT in Wondows XP SP2
By redrock1 in forum Capturing and VCRReplies: 3Last Post: 21st Mar 2008, 02:03 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11 -
ATI 7500 All in One Wonder
By justmehere in forum Capturing and VCRReplies: 3Last Post: 8th Feb 2008, 16:08
