  1. Hi
    I have recently tried to put Scoobydoo on DVD from a SVCD.
    I have the Scoobydoo as 1 x 1.4gb mpeg
    I open TMPGEnc and add the mpeg with the wav audio, i set up the settings as usual etc.. setting the films as NTSC (tried both low quality and high)
    Now when im at the screen where you choose the % of the DVD you want the film to be in size - TMPGEnc see's the mpeg as being 100's of hours long and this then says the DVD is 900 +% the size of DVD
    does anyone have any ideas, or had the same happen to them???
    cheers Jono
    Apr 2002
    Norway
    Use "Source range", click "Move to end frame" and "Set end fram".
    It will now set the end of the movie to where it actually ends, and all will be nicely in size.
