I just thought I got the hang of everything when using TMPG. When I tryed to encode 2 films from AVI to VCD I found the sound didn`t come through. So I checked here and found you had use Virtua Dub to strip the sound to wave form then load it up into TMPC again with the Vid to sort that out. It did, A treat. I did this with both films then when I came to put the 2nd CD of each film in my Standalone player I noticed the sound was out of sync by a good 5 seconds. Is that a common problem.
I encoded it by using stting, source, for the first part (start , end in middle)
And for the second (start middle, end at end)
PS I did think the sound was a lot better. Is it better to use Vitua Dub to strip the sound for all AVIs that you want to convert.
Results 1 to 1 of 1
Virtual Dub 1st & 2nd Pass Encoding
By OrchestraAndChoir in forum Video ConversionReplies: 10Last Post: 22nd Jul 2012, 07:20 -
Virtua dub apend video & using new audio problem
By tinzun in forum Newbie / General discussionsReplies: 8Last Post: 1st May 2011, 11:34 -
Burned a 2prt avi to dvd Loss of audio on 2nd part of the movie.
By Ryanmhindman in forum AudioReplies: 2Last Post: 22nd Sep 2009, 14:43 -
two part film wont play ?
By lou41888 in forum Authoring (DVD)Replies: 4Last Post: 31st Dec 2008, 20:49 -
Audio sync problem converting 2nd part VOBs->avi with VDubMod [fixed]
By blueprint in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 00:07
