I am using AIW Rage 128 on a 450 PIII system.
I use VirtualDub to capture a Camcorder via S-Video and Audio connectors.
The sound is finewhile I am capturing however when I play back the AVI the sound has gone
. I have followed the guide "High Quality Capturing with Little Frame Loss in VirtualDub".
If you need more info let me know but I could do with a quick answer (couldnt we all)
This is my first attempt at capturing from my camcorder. I want to create VCD's from the video camera.
Thanks in advance
Gazza
When you check the RECORDING Volume Line In, is it activated? Not the normal volume Line In, but recording volume.
Hello.
Cleaning Up Captured AVI
By Candoo in forum Newbie / General discussionsReplies: 3Last Post: 17th Dec 2008, 14:29 -
Windows Movie Maker - Why is there no sound after video clips captured?
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 6th Dec 2008, 10:45 -
no sound when i captured from dv in adobe prem cs. even hd didn't work
By cannibalcam in forum AudioReplies: 7Last Post: 5th Mar 2008, 08:07 -
when captured avi goes over 4 gigs nothing recognizes it ?
By 99teggsr in forum Capturing and VCRReplies: 11Last Post: 28th Dec 2007, 23:00 -
Ok, captured my video as AVI format
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 19th Jun 2007, 00:37
