I'm creating SVCD and I capture it at 768*576 but should I let TMPGE resize it or should I let Virtual dub resize it?
If Vdub what rezolution then, 480*576????
Encoding is a little bit faster if Vdub does the resizing.
If TMPGEnc has to resize then the encode takes a little bit longer.
Depending on the length of the video:
Longer video - Resize in Vdub
Shorter video - Let TMPGenc do the resize
In Virtual Dub you will want to look for a better resize filter than
the one that comes packaged with Vdub.
TMPGEnc resize problem
By Vatrik in forum Video ConversionReplies: 17Last Post: 15th Mar 2010, 07:27 -
tmpgenc xpress auto resize results in 708 width in 720 frame.
By davexnet in forum Video ConversionReplies: 0Last Post: 27th Jan 2010, 14:49 -
Tmpgenc Xpress 4: I Don't Want To Resize
By Tom Saurus in forum Video ConversionReplies: 17Last Post: 16th Nov 2009, 15:18 -
Can't framerserve vdub to tmpgenc under Windows 7 64 bit
By TheFamilyMan in forum Video ConversionReplies: 2Last Post: 8th Nov 2009, 19:29 -
Resize Divx/Xvid For Portable With VDub: Artifacts/blur
By gordonliu in forum Video ConversionReplies: 6Last Post: 4th Apr 2009, 09:42
