after i converted avi to vcd and burned it with nero and put it in my DVD player, i can only hear the sound, and can't see any image. the screen is black.
what should i do?
please tell me if you know what's wrong,
thanks,
shai
Results 1 to 12 of 12
Specificity and detail are assets when asking questions pertaining to such matters.
Did the AVI play all right on your PC before you encoded it to MPEG-1?
What software did you use to convert the AVI to VCD-compliant MPEG-1?
Did the VCD-compliant MPEG-1 file you encoded play all right on your PC?
What version of Nero are you running?
What brand and model number is your dvd player?
Have you made any VCDs that have played correctly in that player?
Will the VCD that you burned play all right on your PC?
p.s. Please fill out the rest of your "computer details" in your profile; it would have helped a little bit in this inquiry.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
I have the same problem, tried last night to convert a divx to a vcd. I used Panasonic Encoder 2.5. The sound was alright, but the video was all black
I followed the Panasonic guide here at vcdhelp.
What shoud i do?AMD XP 2600+ Barton * ASUS A7N8X-X * 256 DDR pc3200 * Radeon 9000Pro 128mb * 280GB HD * WinXP Pro -
To paraphrase Tony during "Prime Minister's [Dodge the] Question Time": I refer the honorable gentleman to the post I made some moments ago.
Originally Posted by Mirror_Image
Can you help me or not?AMD XP 2600+ Barton * ASUS A7N8X-X * 256 DDR pc3200 * Radeon 9000Pro 128mb * 280GB HD * WinXP Pro -
I have the same problem.
I have Panasonic RP-62 DVD player. I can hear sound with no VIDEO.
MY Avi that I burnt has very good video quality. It plays fine on DIVX.
But MPG that I burnt doenst play on Windows media player. It can play only sound.
I used TMPGenc to convert avi to Mpeg1.
I am using NERO 5.0
Most VCDs play well on my DVD player. I havent had any problems.
I appreciate your help.
Originally Posted by spaceistAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Check the "how to - newbie" section (link on the left), then the "tmpgenc common problems" heading. They list a couple of possible solutions.
I have read that. Followed all the instructions, but with no luck.
One basic question, when I select a avi file in TMPG, and go to file preview, should it play the audio and video? How about the MPEGs that it creates, can it preview those? -
Try installing the Nimo codec pack or Divx5 - look in 'Tools" on the left... your .AVI might have been encoded with a "newer" (unsupported) codec.
The TMPGenc "File>Preview" will play (.MPG, .AVI, .MOV, etc.) video only - no audio.
---Hey, it's my anniversary!
I cannot hear anything from christv pvr 4.99 and up....
By MidnightMike in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2009, 07:44 -
Cannot Hear Audio on AVI
By Squid_uk in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2008, 09:05 -
cannot hear vocals only music
By nirbhayn in forum Newbie / General discussionsReplies: 4Last Post: 15th Jul 2008, 08:48 -
Could someone tell me how to hear sound from this MP4 file?
By ALUOp in forum Newbie / General discussionsReplies: 3Last Post: 5th Jan 2008, 23:41 -
Medion MD 96340 Laptop-Anyone hear of?
By jbitakis in forum Newbie / General discussionsReplies: 8Last Post: 1st Nov 2007, 20:17
