I have converted most of my DVDs to SVCD and VCD without any major problem, however I tried to convert my first NTSC DVD to Pal, but unfortunatly things aren't going too smoothly.
From what I can tell the DVD is NTSC 29.97fps interlaced
Any one have any thoughts?
Best Regards
Amelia
1. Read up on TMPGEnc. There's more good info out there than I can recall.
2. Get TMPGEnc at http://www.tmpgenc.net
3. Check out the SVCD (PAL) conversion settings file which can be loaded.
4. Get TMPGEnc to read the DVD .vob files
5. Convert using the SVCD (PAL) settings
The main thing is to convert the video into PAL format which is among other things (I may be mistaken here, bad memory) 25 fps, 480x576. The SVCD (PAL) settings file should be all set for it. I suggest just converting the video stream by itself, encoding the audio in another program and muxing the two together afterwards. TMPGEnc doesn't handle audio that well.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
how to slow down interlaced Ntsc recording of Pal ?
By spiritgumm in forum Video ConversionReplies: 20Last Post: 11th Oct 2010, 20:59 -
converting PAL (25fps) to NTSC(23.97fps) with audio
By drew24 in forum MacReplies: 6Last Post: 21st Dec 2009, 10:45 -
Best way to get 29.97fps progressive video onto NTSC DVD
By Ste in forum Video ConversionReplies: 6Last Post: 23rd Oct 2008, 14:59 -
24fps HDV (NTSC) to 29.97fps DV (NTSC)
By vodnick in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 3rd Jan 2008, 07:36
