I had 2 divx files i wanted to join, and it said it couldnt because they had different audio rates?? or something?
What???
Results 1 to 12 of 12
Here is an image of the both in the file info, what do i edit? Can i edit wats wrong??
And, when i load the first movie, it gives me this :
Then, when i load the second movie with it, it gives me this:
If your intention is ultimately to convert to (S)VCD, you may as well convert each part separately. If you just want a joined DivX to keep as DivX, your best bet is to to use audio>full-processing mode, and save out the uncompressed wav for each part. Then load the first DivX into vdub, choose video>direct stream copy, and audio>full processing mode. Browse to the wav file you extracted for the first part and choose compression, selecting mp3 at 96, 128 or 160, depending how concerned you are about the filesize. Then save the avi. This will recreate the avi with CBR audio. Do the same for the second DivX, choosing the same mp3 compression. Now you will be able to join them.
It sounds like one of your DivX may have ac3 audio, in which case you cannot save out the audio - you need a slightly more involved way to get the wav. Is it the same for both DivX?
Yes, it is the same for both of them. How would i go about combining them or getting the WAV?
Thanks! -
If the audio is ac3, you'll need to use something like Graphedit or Headac3he. Check out http://forum.vcdhelp.com/viewtopic.php?t=91588
I dont want to convert it to VCD. Im trying to convert the movie to a DVD, but i needed to combine. Should i still use this??
So far as I know if the audio is ac3 you will need to convert it first. However, converting to DVD is outside my experience, so perhaps someone else has an idea? However, I would go ahead with the conversion just to make sure it actually is ac3! Was there no nfo with the movie?
When i use Headach3he i get an error like "cannot find data chunk"
I am like so fed up with this, please anyone if u can help, post.
[solved] virtualdub + no decompressor prob...
By j6044 in forum EditingReplies: 18Last Post: 4th Sep 2010, 07:14 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
Error In Virtualdub Joining Two Like DV Files. Help?
By kpoman in forum EditingReplies: 2Last Post: 7th Jan 2009, 11:34 -
audio sync prob dazzle dvc-150 and virtualdub
By zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 13:34 -
Joining AVI videos in virtualDub ?
By Dj-DuDu in forum EditingReplies: 3Last Post: 13th May 2007, 13:31
