I Have a NVIDIA 64MB GeForce2 Video Card with TV-OUT. Since it has TV-OUT, can I use that to record things from the TV to my computer? Or do I need one of these capture cards or tv-cards or whatever?
-----SMOKE WEED [=
TV-Out would mean from your computer to your TV set. You would not be able to capture video with it.
To record to your computer you need either a video card with a TV-IN or a capture card. Just as the quality from your TV-out is probably LOW-rez mine is 800x600 the TV-IN would probably have the same problem. If you have a Pentium II 500 or equivalent and above, a generic dual function PCI TV/Capture card (not USB) is the way to go based on cost and performance. I have an older AVERMEDIA and I am very satisfied with it. If you are into Mpeg, hardware Mpeg cards are not necessary if you have the PC power and you use the DirectShow filters apps and compatible drivers to let you do software mpeg capture.
Cant get either video capture card to work
By ralphey in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2011, 21:02 -
DVR card BNC Female to regular cable (rg60) conversion
By johnnyfly123 in forum Capturing and VCRReplies: 1Last Post: 27th Mar 2010, 16:49 -
Pioneer BDR-205 requires HD video card to work??
By lafjax in forum DVD & Blu-ray WritersReplies: 4Last Post: 1st Jan 2010, 12:51 -
How do I get 16:9 DVD video to play correctly on my 4:3 (regular) TV?
By chaacmool in forum Authoring (DVD)Replies: 1Last Post: 7th Oct 2009, 14:46 -
Can't get DVI out to work on video card
By Teutatis in forum ComputerReplies: 2Last Post: 29th Jan 2009, 01:22
