I have some video files in .avi from a friend that i really want to watch, but when i try to open it i get an error message, but you can hear only the audio playing.
Only the audio will convert in TMPEG too, and only the audio will play! I have DivX on my computer, so what codec do i need to play these ?
p.s. I'm running Windows ME and it doesn't work on Windows 2000 either.
which divx version do you have?
I believe the latest is 5.02.
A lot of recent video files on P2P are showing up with this compressor. -
if in doubt you can try installing divx 3, 4, 5.x
or one of the 'codec packs' such as NimoCodec Pack.
http://www.btinternet.com/~nimosiro/ -
There is a codec called Xvid that is a mpeg 4 codec that I had to use on some files that I have downloaded.
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
Need A Codec
By TheVille in forum EditingReplies: 8Last Post: 14th Jan 2009, 09:40 -
Is there a codec for this
By jakefree in forum Video ConversionReplies: 0Last Post: 13th Jan 2009, 21:19 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41
