Hello again, all-I was wondering if anyone could enlighten me on how I can add subtitles to captured AVIs. Most of the info on this site centers around grabbing subtitles off of DVDs. I was just wondering how I could add subtitles to a captured AVI...I have downloaded Sub Station Alpha, but it talks about Gen-Locks, Amigas, and .wav timing...is there a filter I can use for either VDub or AVISynth to do this??? Thanks in advance....
You have all you need. I am a newbie, so feel free to accept this answer with a grain of salt.
Run your video with a pad and pencil in hand. I use VDub, because I can stop it with the space bar, or use the slider.
When you get to where you want your first subtitle, stop. Write down the time and the subtitle (or mnemonic) on your pad, and how long you want the subtitle to last. Repeat until you finish your video.
Load Substation Alpha. Write in your first subtitle, go to the upper left hand corner of the program screen, put the start time of your subtitle, tab to the duration block and enter your duration time there. Hit Return, and the program updates the end time for you. Continue until you complete all your subtitles.
Save the file as an *.ssa file.
Go back to VDub. Open your filters. Use subtitler, or your favorite subtitling filter. Select your .ssa file, and either frameserve to your encoder, or save the the video as an .avi file.
Your new video file now has your subtitles -- Voila!Hello. -
wow, I was hoping it was that easy but I just wasn't sure...I didn't believe that it could be true...man that is great...now if I can just stop this Premiere download...
thanks a ton tommyknocker!
Problems when trying to add subtitles to MKV and AVI
By Gabriel_HS in forum SubtitleReplies: 4Last Post: 23rd Jun 2012, 11:18 -
add subtitles using AVI Demux problem
By pensioner in forum Newbie / General discussionsReplies: 5Last Post: 4th May 2010, 02:12 -
permanently add subtitles to avi
By RZ_29 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2009, 09:57 -
How to add subtitles to AVI?
By sepehr_s in forum SubtitleReplies: 1Last Post: 16th Apr 2008, 14:10 -
add Optional subtitles to AVI files?
By pck76 in forum MacReplies: 1Last Post: 17th Nov 2007, 18:39
