I downloaded a .bin and burned it, it was a vcd with chapters and menus. The problem is that towards the end the audio and video stopped synching up. Can I convert the vcd .dat file to MPG or AVI, (don't know which is better) and try to fix it using Tmpgenc or something of that nature? If I can, is there an easy way to turn it back into that .dat file so the spiffy menu's still work?
Thanks!
Look to the left. "How to - convert". The info is there.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
aww Just let him know. um well since you burned a .bin file only then its not an actual vcd unless it also came with a .cue file you burned also in the same cd. and to extract i think you can use vcd gear to extract the avseq1.dat which is the mpg or use a program called isobuster.exe i have it thats what i use to extract the mpgs from a vcd. Good Luck!
EvErY0nEs A HaTeR BuT mEE! -
Yep, I did find the link and am using the wonderful vcdgear proggie, now I have to figure out why when the large .dat is converted into a .mpg it splits it into pieces and I can only 'run' the first piece. I want to try to re-sync the video/audio you know!
And yes, it came with a .cue file (that was pointing to the wrong folder and I had to fix it)
I guess if this was easy, we wouldn't need the noob guides! -
Try just copying the .dat file from the VCD onto your HD and then renaming it with a .mpg extension.
Works for me. -
I need to do the same. But when using That gear program about 16 percent in everytime I tryed to load the dat. file it say error in sync and stops Any ideas
Converting from DVD to format to play back using media share/directv dvr
By Nosey249 in forum Video ConversionReplies: 0Last Post: 24th Feb 2010, 09:35 -
Can I fix a VCD?
By Haopengyou in forum Authoring (VCD/SVCD)Replies: 6Last Post: 1st Feb 2008, 00:26 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Back up and converting
By Gustav Klimt in forum MacReplies: 2Last Post: 25th Jun 2007, 15:17 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 11:20
