hi
i have an avi file
i converted it using ulead and another program called EditStudio
but it gave me a really bad quality
tell what is the best program for converting AVI to Rm
or how can i make it with high quality
thx alot
Ulead Video Studio anyway, uses Real Video 7, instead of the current 8(and comming 9). So goto http://www.realnetworks.com and download their free encoding utility to convert it to real media. It also depends on what quality setting your using. The 56k setting will look crappy no matter what you use. So for realively small file sizes and good video, go with 256k Cable Dsl. Higher if needed.
I will not eat oysters. I want my food dead - not sick, not wounded - dead.- Woody Allen
fonoop.com
Converting my HD DV movies to play on TiVo HD in high quality
By nashmarkt in forum Newbie / General discussionsReplies: 24Last Post: 7th Sep 2010, 13:21 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 13:38 -
Problem when converting to High Quality framerate
By hzgg2 in forum EditingReplies: 3Last Post: 30th Aug 2008, 17:14 -
Converting from flv to high quality video format
By venus in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2008, 13:47 -
Need an expert advise on converting AVI (or SWF) to MPG High quality video
By oavs in forum Video ConversionReplies: 10Last Post: 10th Jul 2007, 14:41
