i've tried direct stream and full processing mode in virtualdub... both can't work... even in direct stream, i rename the captured wav to .ac3 and tries to encode the ac3 file to wav using besweet and headach3e... both cannot work too...
nimo codec, divx ac3 codec.. wadever ac3 codec also installed... just cannot rip out the wav file.. this is getting very annoying...
is there an easier method to rip of the audio from avi encoded in ac3 audio...
pls advice~ thanks...
Whats the error message your getting in headac3he when you try to load the ac3 file? you did rename it with the extension of ac3, right?
How to rip Bluray encoded in VC-1 and DTS HD
By Victor D in forum Video ConversionReplies: 21Last Post: 1st Oct 2011, 12:44 -
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 20th Jun 2011, 23:56 -
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 21:53 -
Rip DVD to Divx/Xvid with AC3 Audio
By dudeman316 in forum DVD RippingReplies: 6Last Post: 3rd May 2009, 03:25 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 18:55
