I would like to take images from video captured in MPEG1 VCD format. My goal is to use them in creating menu backgrounds, CD labels and jewel case inserts for my VCDs. I am currently using Ulead VideoStudio 5 for capture and editing, Ulead DVD MovieFactory for authoring, and Adobe Photoshop 6 for image editing. This has got to be possible! Suggestions anyone? Thanks!
You can open MPEG-1 files in VirtualDub, and scroll to the frame you like, then snap a screenshot from there (I think that's near the bottom of the 2nd or 3rd pulldown menu). I don't have VDub installed, or I would be more exact.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
o.k.
Now let's add to that. What do you do if you want text on the chapter or menu? -
load mpeg into vdub
go to whichever frame you want to capture
then press CTRL 1
to capture the source frame
then open up photoshop
CTRL N for new file
then Edit -> Paste
and it'll paste it into that new file
then work on it from there
MPEG I-frames to JPEG
By bluethunder888 in forum ProgrammingReplies: 13Last Post: 9th Jul 2011, 17:54 -
working with universal M-JPEG (not MPEG) HD codec
By devdev in forum EditingReplies: 0Last Post: 8th Jan 2010, 06:58 -
Screensaver for WMV,MPEG-2 clips and JPEG pics
By rch15 in forum Software PlayingReplies: 0Last Post: 18th Aug 2008, 00:14 -
How do I convert Motion JPEG to MPEG-1?
By TheEvilHammer in forum Video ConversionReplies: 6Last Post: 18th Oct 2007, 18:58 -
create short MPEG video from one JPEG image
By mb508 in forum EditingReplies: 10Last Post: 14th Oct 2007, 06:32
