Excuse my english, i'm speek french !!!
I download divx movie and i try to convert ot to vcd !
i extract audio with virtualsub, load my avi and my new wav in tmpgenc and follow the guide for conversion and i always got my video and audio out of sync.
os=windows 2k
pentium 3 1.4 ghz with lot of disk space
Help me please !
These can be a wobbly one, but when you are burning this VCD are you sure you are burning itin the right template through your program i.e. if its PAL then choose PAL and vice versa with NTSC I know that these can cause lip sync issues when burning a PAL onto a NTSC template.
Hope it helps
DaveWelcome my son, welcome to the machine. -
Are the DivX files the same exact framerate as VCD? You can check this in Virtual Dub's file information. Even a few thousandths of an FPS will throw you out of sync gradually. Sometimes lazy folks will just change the frame rate in Virtual Dub to get around a synce problem - until you try and convert the avi to a VCD compliant file.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
DIVX sound and video not in sync
By DarkPhoenix77 in forum MacReplies: 2Last Post: 27th Feb 2009, 12:48 -
sync issues with DVD to DivX conversion
By snafubaby in forum DVD RippingReplies: 12Last Post: 24th Dec 2008, 03:10 -
Standalone Divx player out of sync
By Tool Man in forum Newbie / General discussionsReplies: 5Last Post: 18th Nov 2008, 20:31 -
Divx sound sync issues
By hotsalt in forum Video ConversionReplies: 1Last Post: 11th Apr 2008, 15:18 -
Burned my first divx using Nero but they are not in sync
By Taylor in forum Newbie / General discussionsReplies: 6Last Post: 4th Sep 2007, 00:07
