I have Power VCR II and I have only recently started to use it.
How can I capture to burn an SVCD with the file. There is a built in template for standard VCD's but I do not see one for SVCD.
I do not want to have to re-encode.
Thanks,
~dev
You didn't say what capture card you were using. If you were using the ATI TV Wonder, here's a post that helped me a bit...
http://forum.vcdhelp.com/viewtopic.php?t=88306&highlight=Animation and geeky reviews and podcasts at
Cartoon Geeks (http://www.cartoongeeks.com) -
Yes I do have an ATI TV-Wonder. The full PCI version.
Your registry fix seemed to help. THe main problem I was having was that there was no preset 480x480 resolution so I could not record compliant SVCD files on the first go.
I will try this and let you know how it works.
~dev
Problems with capturing using ION VCR 2 PC
By mostly_useless in forum Capturing and VCRReplies: 0Last Post: 21st Dec 2011, 19:16 -
Looking for Good VCR for Capturing
By zerowalker in forum Capturing and VCRReplies: 0Last Post: 28th Nov 2011, 18:56 -
VCR capturing question?
By s3r19lk1ll3r in forum Capturing and VCRReplies: 1Last Post: 17th Oct 2010, 22:26 -
Canopus ADVC110 w/Power Director audio stutter problems when capturing?
By popflier in forum Capturing and VCRReplies: 7Last Post: 6th Mar 2010, 04:48 -
Having problems capturing from VCR
By Confused Chimp in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2007, 03:41
