I have a Radeon DDR 64mb VIVO with DirectX8.0/dx8cap installed. I installed the latest drivers and software for my card, but still no luck. I'm running a Tbird 850mhz, 128mb RAM. If you have any advice whatsoever, I would be pleased to hear it.
sounds like you're running win9x. VirtualDUB Capture will work fine in win2k. I have no idea why but it does.
uhh... sounds like win2k... win98 with vxd drivers for my tvcard works perfect, win2k with Lovein' beta-state wdm-drivers suxxx a lot.
btw, i've got a terratec terratv+
-Elchknie -
RHB
Have you installed the VFW wrapper for your ATI card? The newer ATI drivers are WDM based and VirtualDub is a Video For Windows (VFW) program. You will need to install the wrapper that basically translates the WDM drivers to VFW drivers, then you will see this device available under VirtualDub.
PCIe/USB AVI Capture device with SVideo and fully functioning Win 7 drivers
By Spektre in forum Capturing and VCRReplies: 3Last Post: 23rd Aug 2011, 19:34 -
DirectShow and Drivers--multiple instances of the same capture card
By Austin Covello in forum Newbie / General discussionsReplies: 0Last Post: 7th Feb 2011, 10:43 -
Help with drivers? Initialization in my Capture Card!1
By hkseo100 in forum Capturing and VCRReplies: 0Last Post: 7th May 2008, 19:41 -
VirtualDub and WDM Drivers?
By 1gnition in forum Capturing and VCRReplies: 3Last Post: 19th May 2007, 11:11 -
To Capture or... To wait for drivers?
By Yeah in forum Capturing and VCRReplies: 3Last Post: 12th May 2007, 17:31
