  1. I've been trying to encode some captured videos into CVD, but when it's done, it either play on half of the tv(using a s-video out thru my computer) or it plays in the middle of the screen stretched out really bad. I use TMPEnc to encode and used the SVCD template, but changing the resolutions. It plays fine on my computer, but when using s-video out, it played really weird. Wondering if anyone has any suggestions. Thanks.
  2. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    If you intent to watch your media through PC, then don't encode to CVD, go for DiVX or better XviD!
    I never heard something close to the weird problem of yours, looks like it is your VGA's drivers fault or something...
  3. never heard of XviD-- is there a guide?
    As an aside, many DivX videos have a lower framerate (~20fps)
    and while they play nicely on a pc, it looks kind of choppy on the TV
    (at least with my tv-out card)
  4. I don't plan on watching it on my computer. I was testing to see if it works, and it turned out to be like that. I too have turned it and played it on my DVD player(apex 600a) and it only on half of the TV. I thought 352x480 is a valid resolution.
