  1. I'm trying to convert some AVIs to MPEGs. If I do so in TMPGEnc, the resulting MPEG has no sound. If I rip a WAV file with VirtualDub, however, and use it as the input in TMPGEnc, the MPEG will have sound, but often it will be out-of-sync with the video. Can you think of any reason why TMPGEnc can't just convert the sound on its own so that I don't have to rip WAV files and then compensate for lack of sync?
    I've installed the Nimo codec pack. Any other ideas?
    Mar 2002
    canada
    i convert my avi's to svcd. i load the avi as is,then convert the whole thing and cut it afterwards. it works for me. the only thing i can suggest is to increase your priorities in the vfapi plug in.
  3. Alright, fixed the problem by installing TMPGEnc 2.57
    Thanks for the help though
  4. Crap. It's happening again. WTF did I do?
  5. I`m having the same problem. Only happening when I encode the second part of a film if I`ve used Virtu Dub to Change the dound to wave,. Its about 5 secs out. I`m stumped as well.
