I am wondering if anyone has any samples of captures using that card
Or at least can someone tell me anything about this card?
Thanx
"Computers are stupid, but they are capable of being stupid one million times per second"
I have win tv primio FM, which is almost the same model...
With a duron 1200 and virtualdub, I can grabb at 720 X 576 with no probs!
Also, I can grabb divx and xvid realtime at 384X288
Work with software mpeg encoders with no probs also.
My personal opinion: It is very good for the price and the abilities!
Also see the Capture cards list of vcdhelp! -
I have the WinTV FM card. I have not been able to capture at 720x576 with Virtualdub but then this is under XP and I understand Virtualdub does not support WDM drivers. With iuvcr I can capture 720x480 but even with a Athlon 1700+ and UDMA 100 drive I get dropped frames. I suspect I need a new drive on the secondary IDE channelOriginally Posted by SatStorm
But the card is pretty good - works well with PowerVCR
Larry -
Yes, you have right: I use only win 2000 and win 98se, never XP...
I don't suggest XP for mpeg jobs in generall. Most software are optimised for w98se and w2k!
LFE audio samples, are there any samples to download and try
By wetduck in forum Newbie / General discussionsReplies: 0Last Post: 14th Mar 2011, 10:17 -
Motion² - first samples!
By nitro1973 in forum Software PlayingReplies: 1Last Post: 25th Apr 2010, 17:00 -
Video Codec Samples?
By prdffy in forum Video ConversionReplies: 8Last Post: 8th Mar 2010, 04:52 -
Make samples ?
By yabbah in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2009, 07:41 -
DVD samples
By michcio in forum Video ConversionReplies: 14Last Post: 10th Jul 2008, 20:53
